1998 Oldsmobile Bravada abs
1998 OLDSMOBILE BRAVADA
JAS_SER
  • 5 POSTS
Brakes problem
1998 Oldsmobile Bravada 6 cyl Two Wheel Drive Automatic
when coming to a stop every time around 8mph the abs kicks in even if its dry why is this happening, and what do u suggest i replace?
thank you
Apr 8, 2010 at 5:20 AM
  • 110,244 POSTS
Check the front sensors for dirt build up.
Apr 9, 2010 at 12:26 AM
JAS_SER
  • 5 POSTS
[quote:a70eb5923b="Jacobandnickolas"]Check the front sensors for dirt build up.[/quote:a70eb5923b] ive already replaced sensor
Apr 9, 2010 at 4:23 AM
  • 110,244 POSTS
Was the wiring in good condition?
Apr 9, 2010 at 5:33 AM
JAS_SER
  • 5 POSTS
yes should i spary like wd40 in the sensor hole on the hub? or do u think it needs replaced as well
Apr 9, 2010 at 7:58 AM
  • 110,244 POSTS
If you are using the spray to clean, use something that will evaporate quickly like brake cleaner, starting fluid... Oil doesn't evaporate and can cause a short.
Apr 9, 2010 at 12:34 PM
