1998 Oldsmobile Bravada 1998 Bravada will not come out of P
120,000 MILES • 6 CYL • AWD • AUTOMATIC
ZADABE2002
Just happened for the first time this past Saturday. Just purchased it two weeks ago and this is the first time I have had something to go wrong with it. Has been operating fine until now. Once repaired, should I expect this to happen again?
May 23, 2009 at 11:31 PM
MERLIN2021
  • 17,250 POSTS
Probably a minor issue, either the shift lock actuator, or the swtich on the brake pedal. Once fixed it wont keep reoccuring!
May 24, 2009 at 12:34 AM
ZADABE2002
Thanks for the help. I am not mechanically inclined so could you please let me know where each of these are located on the vehicle so that I can check them out?
May 24, 2009 at 2:03 AM
MERLIN2021
  • 17,250 POSTS
Look on the brake pedal arm, as you travel up the arm, the stop light switch will be found, test it. Do the brake lights work? Any broken wires or melted connector?
May 30, 2009 at 2:35 AM
