1997 Oldsmobile Bravada no spark no fuel
1997 OLDSMOBILE BRAVADA
144,050 MILES • 6 CYL • AWD • AUTOMATIC
ROHTOM
Ive got a 97 Bravada and it just quit running. I replaced the fuel pump, the ignition module, the crank sensor and the computer. It turns over just fine. What could the problem be? thanks
Oct 10, 2008 at 10:02 AM
Do below to determine if its fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Oct 10, 2008 at 10:38 AM
