HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Bravada
Fuel System
Fuel Pump
Relay
SPONSORED LINKS
1997 Oldsmobile Bravada no power to fuel pump
ADELATTE67
MEMBER
1997 OLDSMOBILE BRAVADA
Electrical problem
1997 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
i recently replaced fuel pump, relay. All fuses seem good.
but I dont hear pump working and wont start. Stumped on what to do next.
Sunday, September 19th, 2010 AT 12:41 PM
MECHANIC
Is there power to the relay? Did you check if there was power to the fuel pump before reinstalling the tank?
SPONSORED LINKS
Tuesday, October 26th, 2010 AT 3:22 PM
MECHANIC
After thought. Is the security light flashing when you try to start it?
Tuesday, October 26th, 2010 AT 3:23 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Content
Not Getting Signal To Fuel Pump
My Fuel Pump Recently Stopped Pumping, But I Tested It And It Works, The Relay Works Because I Manually Tested It But There Is No Signal...
Asked by
marked0210
1997
OLDSMOBILE BRAVADA
VIDEO
Replace Your Fuel Pump Relay - Easy Steps
Instructional repair video
Fuel
No Power To Fuel Pump Power Is At Relay And Times Out In 3seconds But Is Not At The Pump.
Asked by
scottmay
1 IMAGE
2002
OLDSMOBILE BRAVADA
2002 Oldsmobile Bravada Fuel Pump
Car Will Crank And Start If I Use Starting Spray But I Am Not Getting Any Power To The Fuel Pump. Replaced The Pump And It Still Won't Get...
Asked by
Jeremy896
1 IMAGE
2002
OLDSMOBILE BRAVADA
2000 Oldsmobile Bravada Fuel Pump Not Kicking On
I Have A 2000 Olds Bravado That The Fuel Pump Wont Turn On. I Have Pulled The Pump Out And Tested It And It Works. Put It Back Together And...
Asked by
shane717
1 ANSWER
2000
OLDSMOBILE BRAVADA
2001 Oldsmobile Bravada Fuel Pump
Replaced Fuel Pump, Filter, Relay And Fuses Still No Pressure. Hooked Old Fuel Pump To The Battery With Two Jumper Wires And It Works. Is...
Asked by
djfatballz
1 ANSWER
2001
OLDSMOBILE BRAVADA
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Fuel Pump Replacement
Engine Not Starting
Online car repair manuals
