1997 Oldsmobile Bravada engine overheating
116,000 MILES • 6 CYL • AWD • AUTOMATIC
LMATT97
my engine temp. keeps climbing up around 260-280 and occasionally there will be steam or smoke not sure which coming off the engine. ill look in the coolant tank and it will be empty ill replace the coolant and it will not fix the problem. this all started after i changed my oil i started up the car and coolant started pouring out under the car.
Dec 10, 2008 at 7:58 AM
SWILLIAMS
  • 597 POSTS
What was done to repair the coolant leak after you changed the oil?
Dec 14, 2008 at 11:23 AM
