1997 Oldsmobile Bravada
LOADER1314
1997 Oldsmobile Bravada 6 cyl
when i come to a stop sign my car seems like it wnats to die. The rpms drop to like 500 and then jump back up to normal. Also when taking off from a complete stop the car hesitates a little bit, but only happens sometimes. Any ideas? Throttle body sensor? Fuel pump? Please help me thank you! Brandon
Jan 20, 2010 at 8:49 AM
HMAC300
  • 48,601 POSTS
try takin some choke cleaner and cleaning the throttle plate. do this with the engine off there is a buildup of oil and stuff that happens and causes this alot. make sure to clean by the idle air control hle a well so you can get the stuff off of that too......
Jan 26, 2010 at 9:42 AM
