1997 Oldsmobile Bravada
1997 OLDSMOBILE BRAVADA
BROWNBOY803
Electrical problem
1997 Oldsmobile Bravada 6 cyl Two Wheel Drive Automatic
i am trying to find the ignition switch on my bravada .i took the lower panel off and the side panel on the steering wheel. i see a small white plastic thing with a small metal rod is that it
Feb 20, 2010 at 5:55 PM
HOMER1967
  • 875 POSTS
sounds like you found it,turn the key on and off a few times and if that rod that your talking about moves then that's it.jeff
Feb 20, 2010 at 6:09 PM
