1996 Oldsmobile Bravada Water Bzck up
1996 OLDSMOBILE BRAVADA
FRED GAINER
Air Conditioning problem
1996 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
Sounds like water gurgling or floating around in the A/C and heater housing under the dash. Donot see any leaks under or on the flootmats. Is there a weep hole that could be clogged and not let the water escape ?? Thanks Fred
Jul 25, 2010 at 8:50 AM
HMAC300
  • 48,601 POSTS
yes there is a hose that goes throught he floor on the passenger side by the front of the transmission on the passenger side. just take a piece o f stiff wire and twirl it around inside the hose to get eht water out. you won't hurt anything and you'll probably get wet.
Jul 28, 2010 at 11:01 AM
FRED GAINER
Thanks for the tip about the water back up in the a/c & heater housing. Now I think the heater core is leaking because I found antifreeze on the driveway this am. How big a job is it to replace the heater core ?? Still do not see any liquid on or behind the floor mat. Thanks Fred
Jul 28, 2010 at 12:52 PM
HMAC300
  • 48,601 POSTS
you have to pull the dash out of the way to get to the heater core. It's ap retty big job as it will taek you probably all day to do and you have tobe careful doing it.
Jul 29, 2010 at 1:30 AM
