1996 Oldsmobile Bravada Very rough idle/loud clanking noise
1996 OLDSMOBILE BRAVADA
149,520 MILES • 6 CYL • 4WD • AUTOMATIC
NANCY3009
I replaced my gas tank(leaking because of corrosion??) and repaired my A/C about 3 weeks ago. When I got the car from the mechanic everything seemed ok. One week later my car overheated due to a leak. The water pump and radiator were replaced. The car is no longer overheating, but now while the car is in idle it shakes like crazy and makes a loud clanking noise and sometimes cuts off. The spark plugs were replaced but it still shakes. Did the original repair of the gas tank and A/C trigger the overheating problem? Is it purely coincidental?
May 30, 2008 at 5:34 AM
MASTERTECHTIM
  • 4,750 POSTS
coincidence. this truck with this many miles is going to break down. its the nature or the beast.
May 30, 2008 at 5:45 AM
NANCY3009
Any suggestions on fixing rough idle prob? Spark plugs were already replaced.
May 30, 2008 at 11:24 AM
MASTERTECHTIM
  • 4,750 POSTS
loud clanking noise bothers me. could be internal engine failure. you really need to have it looked at again. not much i can do without hearing it. sorry
May 31, 2008 at 6:33 AM
NANCY3009
Thank you for your response, it's not what I wanted to hear but it's still helpful:)
May 31, 2008 at 7:00 AM
