1996 Oldsmobile Bravada surging/missing
1996 OLDSMOBILE BRAVADA
DANCHYCNER
Engine Mechanical problem
1996 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
car feels like it is missing then will get power for brief second then feels like it is surging agen or missing the car sometimes stalls but only when at an idle or a stop. when at an idle it idles between 500 rpm and 1000 rpm when I bring it up to 2000 rpm and hold it there with out giveing it more gas it will bounce up to 3000 rpm and back down to 2000 rpm.note when I put it to the floor when in park it wont rev up past 4000 rpm. car feels like it has no power.
WILL SOMEONE PLEASE HELP ME I AM GOING CRAZY TRYING TO FIGUR THIS OUT PLEASE HELP ME!!!
Jan 5, 2010 at 11:21 PM
MATHIASO
  • 1,209 POSTS
Hello DanChycner
Welcome to 2carpros
There might be a fuel supply or a sensor problem.
Lets start with changing the fuel filter if not done yet.
Next, have the fuel system pressure done.
Position the ignition switch and the A/C system in the off position. Install a fuel pressure gauge to the vehicles fuel pressure valve. Confirm that no leaks are present, and with the key on, engine off verify the PSI reading on the gauge. it should be between 60-66 PSI (Pounds per Square Inch) If below the parameter, the fuel pump must be replace.
Check for engine code(s) if there is engine light or not because sometime engine light bulb is burned out or the code is pending and not shown yet.
TP sensor/ MAF sensor could also cause that problem.
Get back to me with what you find
Jan 6, 2010 at 12:14 AM
DANCHYCNER
when I took the fuel lines off the fuel filter no gas sprayed out just dribbled.
Jan 6, 2010 at 1:21 AM
MATHIASO
  • 1,209 POSTS
Change the fuel filter.start the car and let see if the problem still there,
If it is, have the fuel pressure checked.
Do everything I asked and get back to me.
thanks
Jan 6, 2010 at 5:09 AM
