1996 Oldsmobile Bravada rough idle
180,000 MILES • 6 CYL • AWD • AUTOMATIC
DAN LASCO
if i change out the throttle control sensor will this fix this problem
what does the MAP sensor do?
updated 4-9-10
I am trying get answers to "rough idle" on a 1996 oldsmobile bravada
i have changed out the idle control sensor and that helped a little, i have put a complete tune-up except ignition coil, will changing out the throttle control sensor and the pick up coil help eliminate this problem, i also replaced the battery and air filter.
Also what about replacing the oxygen sensors?
thanks for your help!
Daniel
Apr 2, 2010 at 2:10 AM
  • 110,248 POSTS
What is the problem? Also, the MAP is a manifold absolute pressure sensor.
Apr 9, 2010 at 12:50 AM
  • 110,248 POSTS
Daniel:
Before replacing everything, has the check engine light come on? Also, have you checked for vacuum leaks?
NOTE: All of the things you mentioned could fix the problem, but the parts could still be good.
Let me know about the check engine light.
Apr 9, 2010 at 12:40 PM
