1996 Oldsmobile Bravada grinding noise in right front
1996 OLDSMOBILE BRAVADA
100,000 MILES • 6 CYL • AWD • AUTOMATIC
MTILL47
I changed the wheel bearing and the noise is still there.it sounds like a bad wheel bearing but i know it isn't the bearing.
Feb 8, 2009 at 1:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does noise occur at any speed, while turning or going straight etc.. ?
Have you inspected power steering fluid and brake pads ?
More information about this issue can be found on our Car Repair Troubleshooting page, linked below..
https://www.2carpros.com/first_things/front_end_popping_ticking_noise.htm
Let me know if you need further assistance.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 9:17 PM
