My olds Bravada will not start in the mornings. I have to turn the key on let it sit for a couple of seconds, then turn it off. Repeat that again then start it. Once I do that the truck will run fine the rest of the day. Ok so that tells me there is something causing the fuel to depressurize in the system. Could this be a bad fuel pump? Regulator? Filter. I have a shop saying it is the pump. But the pump has to be working if it will still pressurize the system.
SPONSORED LINKS
Sunday, March 21st, 2010 AT 8:50 AM
