Engine Mechanical problem
1996 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
car will barely pull its self and then for a breif moment will get power and go then will barely pull its self agen and some times stalls unless you give it a little bit of gas note only stalls when idleing or when at a stop. when I hold my foot on the gas and hold it at 2000 rpm it will some times bounce between 2000 rpm and 3000 rpm whithout me makeing it do so. and it will not go past 4000 rpm when you put it to the floor.
SOME ONE PLEASE HELP ME I AM GOING NUTS TRY TO FIGUR THIS OUT !!!!!
Jan 5, 2010 at 10:58 PM
