1995 Oldsmobile Bravada fule
VALDEZ08
1995 Oldsmobile Bravada 6 cyl Two Wheel Drive Automatic
only if i prim the carb. the car will run could this be my fulepump
Oct 16, 2008 at 12:43 PM
  • 75,988 POSTS
Could be the fuel pump if you physically check the fuel pressure with a fuel pressure gauge designed for your system and make sure its within specs. Or you don't have an injection pulses hook up a noid light and check-
Oct 16, 2008 at 1:59 PM
