1994 Oldsmobile Bravada
1994 OLDSMOBILE BRAVADA
180,000 MILES • 4 CYL • AWD • AUTOMATIC
IRISHPLAYER15
Recently I was driving down the road and without any given notice my car shut off. No stuttering. Nothing. Almost like someone flipped a switch on me. There was also no check engine light on. When I tried to restart it cranked but wont turn over. I have plenty of gas (my first thought). I followed Oldmobiles reccomendation of opening the throttle for a little bit before restarting as the engine can be flooded. I could smell the gas when I did this. But on trying to restart, the engine still cranked but turned over. I had to call a tow truck to get me home. I can't afford to take it to a shop and have them diagnos it and charge $500 like I have been quoted. Anyone have an idea what could cause the engine to shut off. And how do i go about fixing it?
Dec 13, 2007 at 8:18 AM
2CARPRO JACK
  • 11,533 POSTS
Start by checking for spark out of the ignition coil.If it has it there, plug coil wire back in and check for spark at the plugs.If none , you will need a test light, get back to me
Dec 20, 2007 at 8:03 AM
IRISHPLAYER15
So I changed out the ignition coil. It was actually the stock one. So that fixed that problem. I ran into another problem. The bolts that attaches the metal fuel line to the fuel filter were both stripped out when I removed them. I had a guy recomment cutting the lines and replacing them with a fuel line hose. The bolt on the filter is really big (5/16 i believe). Any ideas on how to fix this also. Thank you!!!
Jan 14, 2008 at 9:53 AM
MASTERTECHTIM
  • 4,750 POSTS
they sell a repair kit usually in the help isle of your parts store. you can cut out the old line and piece in new metal lines with compression fittings. **94 blazer has 4.3l vortec engine and runs on high fuel pressure, i would not recommend rubber hose, unless you use fuel injection hose and that costs about $10 a foot.
Jan 14, 2008 at 9:58 AM
