1993 Oldsmobile Bravada hesatation and smoke
172,000 MILES • 6 CYL • AWD • AUTOMATIC
JANDS0506
i have a 93' bravada and i changed the cpi feul injectors and topped off all fulids and changed the oil and oil filter. after doing all that i still have a hesatation and heavy white smoke comming out the tail pipe. do you have any suggestions? Thanks Jay
Mar 29, 2008 at 12:09 PM
BLACKOP555
  • 10,386 POSTS
sounds to me like a bad intake manifold gasket.
or its head related ie a warped/cracked head or a blown headgasket.
that causes excessive white smoke.
Mar 29, 2008 at 12:24 PM
JANDS0506
i already replaced the intake manafold gasket. could it be a pvc valve going bad? or do you think its deffinetly a head problem?
Mar 30, 2008 at 2:01 AM
BLACKOP555
  • 10,386 POSTS
pcv valve wont cause white smoke
i think its the heads then or the intake could be cracked on it, but unlikely.
a cylinder compression test will tell you if its head related.
Mar 30, 2008 at 3:19 AM
