Heater core replacement
1993 OLDSMOBILE BRAVADA
75,000 MILES • 6 CYL • AWD • AUTOMATIC
BOBETTE
Is it possible to replace the heater core without removing the dash? Can you give me the basic steps to go thru?
Feb 11, 2008 at 3:00 AM
SQM
  • 6,383 POSTS
In order to remove the heater core, you will have to remove components from the bottom of the dash. That is the only way to access it.
Before taking out the heater core you want to first drain the coolant and remove the heater hoses from the fire wall.
Here is a helpful guide:
https://www.2carpros.com/articles/replace-heater-core
Jan 16, 2022 at 4:48 AM
