1992 Oldsmobile Bravada hy I need some help figuring out wh
MIKE024
  • 1992 OLDSMOBILE BRAVADA
  • 6 CYL
  • AWD
  • 154,000 MILES
My bravada drives fine going down the road and then it starts back firing and like the more gas I give it the slower it goes I just put new spark plugs the platinum ones and wires and put some fuel injecter cleaner in it and its still doin it its like there is a loss of power or something for a second and then its like it pulls out of that and starts driving good again for a few minuets and starts doing it all over again can u help me out if so that would be great.
Monday, September 22nd, 2008 AT 3:05 PM
DBJMBOCK
I had the same problem with my 92 blazer 140,000+miles and after replacing almost everything in the ignition system I took it to the dealership and they sold me $400 worth of fuel injectors (that I had recently swapped out with aftermarket fuel injectors). The problem persisted and then they found that the wires leading to the fuel injectors were coroaded. They replaced the wiring going to the fuel injectors (for another $60) and I never had the problem again.
Thursday, October 2nd, 2008 AT 10:41 PM
