1991 Oldsmobile Bravada Engine timing
1991 OLDSMOBILE BRAVADA
RAYMONDW
Engine Performance problem
1991 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic 80K miles
Are there any vacuum or other hoses that need to be disconnected and plugged when do engine timing on a 1991 Bravada?
Mar 16, 2009 at 12:46 PM
DOCFIXIT
  • 18,828 POSTS
Need to know if engine is 2.8L,3.1L or 4.3L
Mar 17, 2009 at 7:51 AM
RAYMONDW
4.3L
Mar 17, 2009 at 10:15 AM
DOCFIXIT
  • 18,828 POSTS
Disconnect Tan/Black Electronic Spark Timimg by-pass connector wire located near heater housing or near distributor or near electrical junction box cover, GM liked to move it around. DO NOT remove 4-wire connector to Dist. Time reconnect EST and clear ECM
Mar 19, 2009 at 1:17 AM
