2003 Oldsmobile Aurora depressing caliper cylinder on disc
2003 OLDSMOBILE AURORA
60,000 MILES • V8 • 2WD • AUTOMATIC
DJEDWARDS4
How do I depress the brake cylinder piston when installing new rear wheel disc brakes?
Jan 5, 2009 at 8:06 AM
  • 110,240 POSTS
Hi:
When I do it, I leave the old pad in place over the piston and then use a C-clamp to depress it. Also, I recommend allowing the excess fluid to exit through the bleeder rather than pushing it back into the system. Just make sure to close it before air can enter the system.
Feb 19, 2009 at 11:32 AM
