2003 Oldsmobile Aurora battery placement
TWOPIE
Electrical problem
2003 Oldsmobile Aurora 46459 miles
Where is the battery at in the car
Jan 17, 2008 at 3:00 AM
ERNEST CLARK
  • 1,730 POSTS
It's under the rear seat.
Just lift the bottom of the seat cushion straight up and it will disconnect. Your battery and one of the two fuse boxes are located right there. Easy!
When replacing the seat cushion, make sure the two metal tabs line up as you push down on the cushion. (You can't miss them) Push until you hear them "Click" into place.
Dec 29, 2009 at 3:41 AM
