2002 Oldsmobile Aurora Lighting
88,200 MILES • 6 CYL • FWD • AUTOMATIC
INTHEMNTIME
I just bought this car. When you turn the lights on, the lights on the left side of the instrument panel, the on/off button for the driver indication center, a few of the steering wheel control lights, and a couple of radio button lights will not illuminate. I looked for bad fuses, but none looked to be bad. Any ideas? Also, I noticed that the cruise control light is brighter when the headlights are turned off.
Feb 8, 2010 at 5:07 AM
RACEFAN966
  • 5,029 POSTS
If fuses are good and the bulbs are good then I would look into the headlight switch. If you have a digital multi meter and can get to the wiring on the back of the switch I can run you through a couple of tests and make sure it is bad if you like.
Feb 8, 2010 at 11:18 AM
INTHEMNTIME
I do have a multimeter, and would be willing to do the tests. Please let me know. Thanks.
Feb 8, 2010 at 11:31 AM
RACEFAN966
  • 5,029 POSTS
After looking at the wiring diagram for you car I see that the instrument cluster is powered off one yellow wire to it and then it is dispersed out from the cluster from there. So what I am saying is that either the flexable circuit board on the back of the dash is bad or the bulbs are bad.
Feb 8, 2010 at 11:40 AM
