2002 Oldsmobile Aurora
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BROOKSBILL
The car is equiped with a garage door opener built in the car so you can program your old opener to the car to open your garage, it went out with the trunk lid opener and the gas lid opener and the unlock button on the key ring will not work. All the other functions on the key ring still works (lock the door, alarm). I tryed to check the fuse boxes, under the hood and under the back seat, but I haven't found a blown fuse yet.
Thanks
Bill
Oct 22, 2008 at 8:40 AM
  • 110,246 POSTS
Bill:
It sounds like a problem with the Body Control Module (BCM). That is what I would check first. You will need to have a mechanic with the proper test equipment do that.
Dec 21, 2008 at 3:12 PM
