2001 Oldsmobile Aurora front hub disassembly
99,000 MILES • V8 • FWD • AUTOMATIC
JIM FREKER
What size is the large main bolt that holds the assembly to the axle? Do you have the step by step instructions?
Jun 23, 2009 at 12:46 PM
RACEFAN966
  • 5,029 POSTS
Ok the nut size could be either a 32,34 or 36mm. I would take it to the parts store and let them know you want to buy the socket and if they would let you take it outside to the car to see what size will fit it. As for R&R of it. What would like to replace the axle or the hub assembly? Let me know and I will instruct you from there.
Jun 24, 2009 at 3:05 AM
