2001 Oldsmobile Aurora Crank Sensor
LDG
Engine Mechanical problem
2001 Oldsmobile Aurora 6 cyl Front Wheel Drive Automatic
Where is the crank sensor located
Nov 1, 2010 at 2:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if 4.0L , there are 2 crank sensors on this vehicle, both located on the lower left side of the engine near the oil filter
if 3.5L engine, crank sensor is on the lower right side of engine above the starter
Nov 1, 2010 at 2:17 PM
ERNEST CLARK
  • 1,730 POSTS
The starter would be on the right side of the engine, while the crank sensor is on the left, but both face the front of the car. Also, be careful with the sensor as they are delicate, and also check the wiring/connector for damage. Sometimes there's nothing wrong with these sensors, but the connector is dirty/corroded, or the wiring is burnt.
Nov 12, 2010 at 8:51 AM
