2001 Oldsmobile Aurora brakes
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMES835
i replaced rotors and shoes on front and i still have a surging like the rotors are warped
Feb 22, 2008 at 10:46 PM
MERLIN2021
  • 17,250 POSTS
How did you put the tires on? Use a torque wrench to do it? Drive the car and if when you step on the brake the front seems to shake or the pedal bounces, it the front rotors, if the bouncing is felt more in the seat it is the rear brakes, also check the tires for a shifted belt...
Feb 22, 2008 at 11:35 PM
