2001 Oldsmobile Aurora
BIG TANK
  • 2001 OLDSMOBILE AURORA
  • V8
  • FWD
  • 11,620 MILES
Aurora want start unless I turn the key 20 times then it will start, all my lights are bright, will not start on one turn. What can that problem is.
Wednesday, April 28th, 2010 AT 7:10 AM
LEGITIMATE007
  • 5,121 POSTS
Could be your ignition switch, could be the wiring being corroded, at the ends or inside the wire itself, a bad connection, or simply the starter or the starters connection all those areas will have to be checked, one more thing, try starting it in neutral.
Tuesday, May 18th, 2010 AT 3:07 PM
