1999 Oldsmobile Aurora transmission has no reverse
1999 OLDSMOBILE AURORA
120,000 MILES • V8 • FWD • AUTOMATIC
K_BASEY
replace trans with one from 94 aurora with blown engine oil was clean and no metal in pan had 89000 mile on it goes threw complete shifting range but no reverse
Jan 28, 2010 at 4:19 AM
  • 110,244 POSTS
We recommend staing with direct fit parts because when you jump around with years, sensors are different and always seem to cause problems.
Has the check engine light ever come on? If not, you need to have it checked by a trans tech to determine if the transmission is compatable with the newer year vehicle.
Feb 13, 2010 at 5:11 AM
