1999 Oldsmobile Aurora radiator
CHRISG57
Engine Cooling problem
1999 Oldsmobile Aurora V8 Front Wheel Drive Automatic
need to replace ,probably will need some diagram and tips to finish that job , PLEASE !
Sep 15, 2010 at 3:46 PM
  • 110,246 POSTS
The radiator is a straight forward job. First, disconnect the neg battery terminal. After that, drain the coolant from the radiator and remove both the upper and lower radiator hoses. Please note, coolant needs to be recycled and should not be allowed to drain onto the ground. After that, remove the fan shroud, the two upper retaining bolts from the radiator support, the transmission lines and any aux cooling systems that may be attached to the radiator. The radiator should pull out at this point.
Reverse the sequence to replace.
Oct 26, 2010 at 12:13 AM
