1999 Oldsmobile Aurora Check engine light is on due TC Stuc
92,000 MILES • V8 • FWD • AUTOMATIC
OLDSFF219
The valve works but the computer is not recognizing the opening and closing of the TC valve. The valve can be controlled by an mechanics computer but not by the actual computer that is in the car. Its been reset about 5 times but check engine light always reappears. One mechanis says to service the trans and an other says to change out the computer. Which would be best to solve this issue? Thanks and hope to hear your professional opinions.
Apr 9, 2009 at 6:11 AM
  • 110,248 POSTS
I don't see how servicing the transmission will repair this issue. I would make sure there are no damaged wiring or bad connections. If there is no signal from the computer, then it will need replaced.
Sep 15, 2009 at 5:43 AM
