1999 Oldsmobile Aurora BOLTS BROKE WITH LUG NUTS ATTACHED
1999 OLDSMOBILE AURORA
146,578 MILES • V8 • FWD • AUTOMATIC
BIGMOMMAJ
WE HEARD THE TIRE MAKING A NOISE SO WE STOPPED TO CHECK IT AN WHEN WE REMOVED THE PLASTIC PEICE WE DISCOVER TWO OF THE BOLTS THAT HOLD THE TIRE IN PLACE HAD BROK OFF & WERE JUST LYING LOSE IN THERE. CAN WE REPLACE JUST THE BOLTS OR WILL THE WHOLE PEICE NEED TOBE REPLACED??
Feb 10, 2009 at 7:33 AM
  • 110,244 POSTS
Hi:
If the stud has broken, replace both. You will need to remove the wheel, caliper and rotor to remove the broken stud and replace it.
Let me know if you have questions.
Feb 19, 2009 at 10:55 AM
