How do I find / Change the thermostat in a '98 olds Aurora
Jan 23, 2008 at 4:47 AM
JRT
MEMBER
FOLLOW UPPER RADIATOR HOSE FROM RADIATOR TO ENGINE. THE HOSE WILL BE CONNECTED TO THE THERMOSTAT HOUSING.
TO CHANGE, DRAIN COOLANT, REMOVE HOUSING, REPLACE T-STAT, PAY CLOSE ATTENTION TO HOW IT COMES OUT (IT WILL ONLY WORK IF INSTALLED IN THE CORRECT DIRECTION).
Jan 23, 2008 at 5:18 AM
