1998 Oldsmobile Aurora not getting warm
90,000 MILES • V8 • 2WD • AUTOMATIC
KELJO104
My 1998 oldsmobile aurora does not blow hot air it blows air that is warmer than outside but I'm still freezing...
Jan 26, 2009 at 5:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First inspect coolant level to ensure it is full. If OK, let the engine warm up and turn heat to High. With this, feel the 2 hoses coming from heater core under hood, near firewall. They should both be warm to touch. If one or both are cool then your heater core is clogged or faulty.
Post results and I will follow up.
Thanks for using 2CarPros.com!
Jan 26, 2009 at 6:07 PM
