1998 Oldsmobile Aurora highway shimmy
1998 OLDSMOBILE AURORA
81,000 MILES • V8 • FWD • AUTOMATIC
GIANNI D
I've been experiencing a slight wheel vibration when driving on the highway. The vibration starts at around 60-65mph and it doesn't go away. I have had the suspension checked several times by 9 different mechanics. Had both wheel bearings replaced. Brake pads and rotors have been replaced. Shocks/struts have been replaced. New Michelin tires have been road force balanced with great numbers. The tire shop found a rim that was out of round and it was replaced with a good used one. After all these repairs I still have a shimmy. It seems that it varies in frequency and it doesn't vibrate in all roads. The last thing I was told is that the CV joints might be going bad, but I really don't understand why because they are not making noise.
Any suggestions?
Thanks in advance,
G
Aug 14, 2008 at 9:48 AM
  • 31,937 POSTS
Hi there,
With all you have done its hard to think of where to go next, i would be checking the front sub frame mounting bolts are tight, the steering rack is tight, there is no excessive play in the rack end bushes, start there.
Mark (mhpautos)
Aug 14, 2008 at 10:24 AM
