1998 Oldsmobile Aurora engine running rough
113,000 MILES • V8 • FWD • AUTOMATIC
BILL BENDALL
Our Aurora has just begun to miss. I wonder if it's bad gas, plugs, or the gas cap. The check engine light has been on for a few weeks. The rough running has just begun within a few days. Engine had been running very strong. This miss is a reaL SURPRISW. suggestions? Thanks
Mar 11, 2008 at 10:15 AM
MASTERTECHTIM
  • 4,750 POSTS
you need a tune up. if you look at the ignition coils at the rear of the engine and remove the plug wires one at a time and put them back on you will most likely find a coil tower that is rusty. replace the plugs and wires and also replace each coil that is rusty. hope this helps
Mar 11, 2008 at 10:17 AM
