1998 Oldsmobile Aurora Car Fires first time when cold, Take
1998 OLDSMOBILE AURORA
165,000 MILES • V8 • FWD • AUTOMATIC
GUNDITO81
My Aurora has recently started to concern me. When you first start the car after it hasn't ran for hours and is completely cool it fires immediately. But when the car has been running and is warm, once the engine is shut down (to run into a store, etc.) when you go to fire it back up it takes 3 to 4 attempts. Once the engine is running it is perfectly fine. Occassionally the car will backfire before it starts when you are cranking the engine several times (only when the engine is warm though). Any tips or advice would be appreciated.
Thanks,
Seth
Feb 27, 2009 at 2:38 PM
Check the fuel pump relay and the fuel pressure if its within specification
Feb 27, 2009 at 2:45 PM
GUNDITO81
Anyone else that may be facing the same issue I was able to determine my issue was caused by a worn out fuel pressure regulator. The part only cost 45.00 and is simple to install. Hope this may help someone.
Feb 28, 2009 at 3:17 PM
