1998 Oldsmobile Aurora abs and traction control light
J KNOLL
Brakes problem
1998 Oldsmobile Aurora V8 Front Wheel Drive Automatic
my abs and traction control light come on every now and then when this happens the abs braking does not work i checked all the abs sensors with an ohm meter i also checked the connections for corrosion etc. fluid level is full fuse is good what should i check next
Feb 11, 2009 at 1:05 PM
  • 110,248 POSTS
Hi:
The two work together. Have the computer scanned for trouble codes. Many parts stores will do it for free. That way it will point you in the right direction.
Let me know what you find.
Feb 19, 2009 at 10:53 AM
