1997 Oldsmobile Aurora Steering column
BOBBBYRENIO
Electrical problem
1997 Oldsmobile Aurora V8 Front Wheel Drive Automatic
Installed used column and will not start. all electronics come on but will not turn over.
Dec 8, 2009 at 11:07 AM
  • 110,248 POSTS
Are you sure the ignition switch is properly adjusted and installed? Maybe the switch is bad. Try your old one if you still have it. Other than that, it could be a neutral safety switch, but chances are it isn't unless you had a problem with it before.
Let me know what you find.
Jan 25, 2010 at 10:11 AM
