1997 Oldsmobile Aurora HEADLAMP REPLACEMENT
127,000 MILES • V8 • FWD • AUTOMATIC
DROMET
Drivers side headlight is out. Owners manual says I have to pull the whole headlight assembly out in order to replace this lamp. Very tight area, I cannot tell which bolts need to be undone to remove the headlamp assembly.
I am reasonably good at doing car repair work, but this one's got me stumped.
Any advice or tips appreciated.
Dec 4, 2008 at 9:01 AM
3000GTRACER1
  • 5 POSTS
There is two bolts and one nut that you will have to remove. You have to use a really good flashlight to do it. You have to have a good handle on the parts as well as they can fall into the bottom cover of the air dam and can be lost forever. The headlight moves out about 1/2 to an inch. Headlight removal requires the removal of the bumper and/or the fender. Took a few hours.
Mar 9, 2009 at 10:00 AM
