1997 Oldsmobile Aurora HEADLAMP REPLACEMENT
DROMET
  • 1997 OLDSMOBILE AURORA
  • V8
  • FWD
  • 127,000 MILES
Drivers side headlight is out. Owners manual says I have to pull the whole headlight assembly out in order to replace this lamp. Very tight area, I cannot tell which bolts need to be undone to remove the headlamp assembly.
I am reasonably good at doing car repair work, but this one's got me stumped.
Any advice or tips appreciated.
Thursday, December 4th, 2008 AT 5:01 PM
3000GTRACER1
  • 5 POSTS
There is two bolts and one nut that you will have to remove. You have to use a really good flashlight to do it. You have to have a good handle on the parts as well as they can fall into the bottom cover of the air dam and can be lost forever. The headlight moves out about 1/2 to an inch. Headlight removal requires the removal of the bumper and/or the fender. Took a few hours.
Monday, March 9th, 2009 AT 5:00 PM
