1997 Oldsmobile Aurora Catalytic convertor codes will not c
135,000 MILES • V8 • FWD • AUTOMATIC
DPN1460
convertor replaced at 110,000 and o2 sensors, code cleared for 150 miles and returned. replaced convertor and used different sensors, code does not clear. car runs great but the light is annoying.
Oct 4, 2010 at 9:51 AM
  • 110,248 POSTS
What code are you getting?
Oct 25, 2010 at 2:57 PM
DPN1460
P420, any help will be appreciated.
Oct 28, 2010 at 7:52 AM
  • 110,248 POSTS
A PO420 is a generic fault code indicating a drop in converter efficiency. I realize you replaced the converter and O2 sensors. Did you check to make sure the sensors are switching between a rich .08 and a lean .03 voltage shortly after starting the vehicle. If there is no change (flat line) you have a bad sensor. Most times a bad sensor will set a sensor code and not the converter. However, I have seen situation where the sensors are good enough to prevent the 02 code but bad enough to set a PO420. Also, is the converter new? Were the sensors you used new? Is the converter OBD2 complient?
Let me know
Oct 28, 2010 at 1:55 PM
