1996 Oldsmobile Aurora Random Misfire trouble code.
224,000 MILES • V8 • FWD • AUTOMATIC
IAMWILLEY83
My aurora has a trouble code of random misfire and has excessive gas consumption. The idle is rough and the after I run it for awhile and let it sit it will take about 5 seconds or more to start. Any Ideas on what the problem may be?
Jan 19, 2010 at 1:14 PM
MATHIASO
  • 1,209 POSTS
Hello iamwilley83,
Welcome to 2carpros.com
Dead oxygen sensor could cause rich condition in all cylinders.or coolant sensor that prevents the computer from going into closed loop, or by a faulty fuel pressure regulator that feeds too much pressure to the injectors.
Check the intake vacuum to see if there is an air leak that's upsetting the overall air/fuel mixture. A couple of overlooked causes here may be a leaky EGR valve or a leaky power brake booster.
Jan 19, 2010 at 3:11 PM
