1996 Oldsmobile Aurora low coolent
74,000 MILES • V8 • FWD • AUTOMATIC
BRIANLAUER
I seem to be leaking coolant but not on the ground...could it be leaking into the oil? and what problems can that cause?
Mar 24, 2010 at 5:49 AM
  • 110,248 POSTS
If you don't see the leak, check the engine oil. If it is, it will have a slimmy light brown / white look to it. Also, check the exhaust for white smoke. That would indicate the coolant is making its way into the combustion chamber.
Apr 9, 2010 at 12:23 AM
