I recently had a flashing check engine light and had codes for RANDOM MISFIRE, CYLINDER 5 MISFIRE, AND LOW VOLTAGE O2 SENSOR. I REPLACED THE PLUGS AND WIRES, CLEARED CODES AND THEN JUST HAD A CYLINDER 5 MISFIRE CODE COME BACK. I replaced the coil pack and now the same CYLINDER 5 MISFIRE code is back and now flashing just occasionally. I can feel the misfire more at idle and when engine is cold, but smooths out when warm and at highway speeds. I am lost....please help!! (4.0L V8 baby northstar, as you already know) Thanks.
Jan 13, 2010 at 4:37 PM
