1996 Oldsmobile Aurora
170,000 MILES • V8 • FWD • AUTOMATIC
SQUEEVO2010
I have a 1996 Aurora and I think its the fan motor but I'm not sure. The settings on the dashboard says its on but there is no heat blowing out of the vents. But sometimes when I hit a bump or hit my dashboard the vents will start working again. What should I do, or what is my problem?
Dec 21, 2009 at 3:52 AM
ERNEST CLARK
  • 1,730 POSTS
When your dashboard says the fan is on, can you actually hear it running? If not, then the blower motor is bad.
If it comes on and off when you hit bumps and/or hit your dashboard, then you have a bad connection and/or wiring.
You'll have to disassemble the module under the dashboard and check the wiring from the dashboard control all the way to the blower motor itself.
Jan 9, 2010 at 5:25 AM
