1995 Oldsmobile Aurora windshield washer pump
134,000 MILES • V8 • FWD • AUTOMATIC
CASHORCARRY
What are the steps to replacing the windshield washer pump on my wife's Aurora? Is the pump located inside the fender on the passenger side?
Oct 15, 2010 at 6:06 AM
  • 75,988 POSTS
Removal & Installation
Vehicle uses 2 washer fluid reservoirs: an inner (upper) reservoir and an outer (lower) reservoir. Washer motor is on the outer (lower) reservoir. Reservoirs are connected by a transfer hose. Disconnect negative battery cable. Remove right front inner fender.
Disconnect transfer hose from outer reservoir. Cut and remove tape securing wiring harness and hose. Remove 2 screws and outer reservoir. Disconnect hose from top of outer reservoir and from washer motor. Disconnect wiring harness from washer motor and fluid level sensor. Remove washer motor. To install, reverse removal procedure.
Oct 15, 2010 at 6:12 AM
