Removal & Installation
Vehicle uses 2 washer fluid reservoirs: an inner (upper) reservoir and an outer (lower) reservoir. Washer motor is on the outer (lower) reservoir. Reservoirs are connected by a transfer hose. Disconnect negative battery cable. Remove right front inner fender.
Disconnect transfer hose from outer reservoir. Cut and remove tape securing wiring harness and hose. Remove 2 screws and outer reservoir. Disconnect hose from top of outer reservoir and from washer motor. Disconnect wiring harness from washer motor and fluid level sensor. Remove washer motor. To install, reverse removal procedure.
Oct 15, 2010 at 6:12 AM
