1995 Oldsmobile Aurora Will not crank over
76,000 MILES • V8 • 2WD • AUTOMATIC
TIMMIL390
northstar engine ran low on oil, shut down. Fixed oil leak problem but it will not crank over. I was told that these cars may have an over ride switch or low psi oil shut down sensor if so where is it located and can it be reset or do I have to replace it.
Jun 17, 2010 at 5:07 AM
  • 75,988 POSTS
Do you hear the fuel pump come on for 2secs when you turn key to run if so-Check the fuel pressure if its within specs, If not check fuel pump and fuel pump relay, if all okay test the fuel pump/oil pressure sending unit-No you don't have a reset button
Jun 17, 2010 at 9:01 AM
TIMMIL390
What I mean by won't crank meaning it won't even turn over. Just bearly a click, starter is fine so is the battery. I can't get the engine to do a one complete rotation. What I'm thinking it could be seized up. I was advised since these are expensive engines that in case of low oil pressure the engine will do a auto shut down until the problem is corrected. Then you have to replace or reset a sensor, maybe a was misinformed.
https://images.2carpros.com/forum/automotive_pictures/540164_95_aurora_1.jpg
Jun 17, 2010 at 9:22 AM
  • 75,988 POSTS
What I'm thinking it could be seized up. Try turning the crankshaft over manually by using the correct size socket on the crankshaft pulley bolt with a breaker bar and turn it 2 full revolutions. If it does its not seized-up
Check the crank fuse, starter relay and passkey module and ignition switch-one more time there's no kill switch
Jun 17, 2010 at 10:56 AM
