1995 Oldsmobile Aurora Shifts hard into Reverse and Drive
1995 OLDSMOBILE AURORA
122,000 MILES • V8 • FWD • AUTOMATIC
PZMQDP
When shifted in Reverse or Drive trasmission 'bangs" in gear. Also shifts harder when driving. Check engine light is on with a code 76. If code is cleared condition goes away but it comes back within a week. Does anyone know if there is a solution other than new/rebuilt transmission?
Aug 29, 2010 at 3:04 PM
  • 110,244 POSTS
A code 76 is a digital egr #2 solenoid error. Has that been checked?
Oct 26, 2010 at 12:20 AM
PZMQDP
Thank you for the reply. I show this a being the Pressure Control Solenoid. Is that correct? It has not been checked. The documetation I found says to make some resistance checks at the PCM connector and the 20-way transaxle connector. Is that were I need to check, and where are those connectors located (where do I look under the hood and and on the transaxle) . Thank you
Oct 26, 2010 at 2:43 PM
TOM442
I have a 95 Aurora doing the exact same thing. Did your problem ever get resolved?
Thanks
Tom442
Apr 13, 2012 at 4:56 PM
TOM442
Turns out my PCM was bad. Junkyard PCM $38.50, swap my original Eprom from inside the PCM. Priceless. You got the last $2 from me.
Apr 23, 2012 at 2:49 PM
